front hub torque
What is the correct torque spec for the front hub axle nut? I found two different #-one for 103ft/lbs and one for 180 ft/lbs. I purchase a set of Timken hubs and wanted to know is there suppose to be a seal included or needed? This is for a 1998 Blazer 4x4. Is there suppose to be some kind of seal or o-ring (none was in the set of hubs)that needs to be replaced would like to make sure I have everything before I start?
103ftlbs for the newer trucks, just like it's stated in the how-to posted in the Tech Article (DIY) section:
4wd Hub/Bearing Assembly Replacement
yuka42
04-28-2014 07:45 PM
chucksnova
09-23-2011 07:38 AM
