Front left vibration
Old Feb 3, 2012 | 04:42 PM
Chillin's Avatar
Chillin is on a distinguished road
Default Front left vibration
So I have read through a few threads on here and it sounds like i have a problem with a bearing or ball joint, but just wanted to get a few more opinions.
I am noticing a vibration/rubbing from the front left side, but only when turning right. As soon as the wheel straightens out or i turn left, it the noise is gone. I don't hear any grinding, sounds more like the tire is rubbing (though i checked and it's not). Could also be explained as the sound mud tires make, but only here it when tuning in the one direction. I haven't had a chance to jack it up yet, but what is the first thing i should check.
Also, what kind of damage could be caused if it is not fixed soon. Doesn't seem bad at all, just a minor rubbing.
Thanks for reading
Old Feb 3, 2012 | 05:19 PM
war00's Avatar
war00 is on a distinguished road
if its getting louder when you turn right, my best guess would be the drivers side bearing is going. because when you turn right the left wheel is turning faster than the right so i would check the left wheel bearing and cv axle and go from there.
Old Feb 3, 2012 | 05:42 PM
Chillin's Avatar
Thanks war00. What kind of damage do you expect could happen if i put a few hundred more k on it? I can fix most problems at my friends place a few hours from where I live. I have no tools or garage where i'm at, so will have to take to a shop if it is necessary to fix immediately
cahlersmeyer
Nov 8, 2011 04:12 PM
stark05
Feb 21, 2009 01:24 PM
Ian McBride
Jun 10, 2007 03:37 PM
rooster
Jun 7, 2007 08:40 AM
hoppy2
Suspension Tech
Nov 17, 2006 03:31 PM
