front suspension problem
OK Ive got a some what loud clunking noise coming from my left front wheel it happens when going through potholes and any kind of bumps so i need some help figuring this out and it is worse in 2wd than 4wd (still clunks but seems to not be as bad)
things i have replaced - all ball joints the left lower one looks a little worn - ideler arm and tie rods - sway bar links -sway bar bushings - cv joint not new but boots are still on possible problems - left lower ball joint but there is no play in the wheel - shock bushings - upper or lower control arm bushings -torsion bars/ keys so let me know what you think it is. |
Check the torsion bar mount as well, give the torsion bar a shake towards the rear they are pretty cheap to replace and could cause the noise you are telling us about.
| All times are GMT -5. The time now is 07:09 AM. |
