Front wheels catching in sharp 4wd turns?
Kso.. Bought this blazer a couple weeks ago from my buddy who I came across on here last night.. everything works fine (after I put a directional switch in the first night) except the 4wd seems to try and lock up the front wheels when I have it engaged and when I turn sharp and slow, say into a parking space. So far I've only made sharp right turns and haven't tried it with the wheel to the left. It does this going forward and backing up. Anyone have this problem before that could give me some insight?
Don't use 4 wheel drive on dry pavement because it locks the front and rear axles together. When turning each wheel moves a different distance and when this happens on a surface like snow, mud or sand the wheels slip a little and everything's fine, but on dry pavement there is to much traction to slip and it causes binding.
- That makes sense, everything goes fine in 2wd.
- Yes I do have push button. I haven't really been listening for a click but then again the super 44 doesn't really grant much to listen for. Than again... the t case does engage as well b/c I started slipping the rears on wet pavement a few days ago then I pushed the 4 Hi and I regained traction.
Then it would be the front axle not engaging and the t-case engaging, I just had this problem with my blazer.
The problem probably is the vacuum actuator.
Being that you have a 95 I'm not sure where your vacuum actuator is, It may be under the battery tray like 96+'s are.
But once you find this, https://static.am-autoparts.com/item/dc058a8127.jpg
Check to see if the seal (on the bottom of the pic) is ripped. If so this is your problem!
Also check if the vacuum line is hook and if it has suction. You can test it by pulling it off, starting the truck and putting it in 4x4, then put your finger over the hole and feel for suction.
No, that would be everything working correctly. When locked into 4wd, there is no speed difference between the front and rear driveshafts. While turning, all 4 wheels are taking different paths. The drivetrain is binding up due to this. One tire has to slip to relieve the bind. Extra power is required to make this happen. Completely normal.
