-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   gearing choices need help (https://blazerforum.com/forum/steering-suspension-drivetrain-36/gearing-choices-need-help-84032/)
toyhauler1283 01-22-2014 08:06 PM
I have a 97 blazer 4 door with 3:42s I'm gonna be running 31" tires here soon and was wondering how hard it is to switch gears in a front its diff. Now I know none of u know me or my skill level so I will add this. The rear diff is not a problem I know all about the preload and gear tooth pattern and backlash. My main concern is taking out the front its and cracking it open. Plus if I'm towing should I go with 4:10 or 3:73. Also how do I tell what size diff I need gears for. I see gm has a 7.25 a 7.6 8.5 there's all different sizes. Thanks for any input or insight u guys might have
Diaita 01-22-2014 08:39 PM
The front isn't any harder that the rear for setting up gears, just more labour intensive. Personally I would go with 4.10 gears, but I prefer a bit more performance over fuel mileage. 3.73 would keep you near stock gearing. Front is 7.2, rear is 7.6 most likely.
toyhauler1283 01-22-2014 09:02 PM
Cool tanks for the input. No blazer came stock with 4:10s did they? I probably can't got to a ez pull and get the whole diff that would seem a lot easier
cleburne red 01-22-2014 10:46 PM
I think some did get 4.10s. Look for rpo code "GT5" in the list in the glove box.
Diaita 01-23-2014 02:52 AM
I have yet to see a Blazer with 4.10s... Maybe an option in the trucks?
El_Beautor 01-23-2014 09:17 AM
I've done quite a bit of research online about this and as far as I can find, while there were some S10's that came with 4.10 gears it was only the 2wd 4 cylindar engines that came with those gears. Almost all the rest all came with 3.42 or 3.73 gears. I have heard of some of the 1st gen Blazers with 3.08 gears too.
Personally if you're wanting different gears to go with your 31" tires I'd suggest just finding a Blazer with 3.73 gears and swap the whole rear axle and front diff. You can get them from a Pick-n-Pull type place for way cheaper than you can get the gears replaced in your current differentials. I did my own on the driveway with normal hand tools. You do need to make sure that you get diffs from the same series as yours. Since you have a 97 you should look for a 95-97 truck unless you're getting new CV axles too. If you get diffs from a newer truck you'll have to replace the front CV axles as well with the newer style because the older and newer styles are not compatible.
toyhauler1283 01-23-2014 07:46 PM
OK thanks for the info
