-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Going from non-high rider to high rider axels? (https://blazerforum.com/forum/steering-suspension-drivetrain-36/going-non-high-rider-high-rider-axels-95012/)
959900s10blazer 07-22-2017 02:58 AM
Hi guys!
So I have to replace my drive side cv axle and I was just wondering how much of a ride height difference is there between a standard 2000 4wd blazer and the ones with the "high rider" or ZR2 option. Can I change my axles on my standard blazer and it still function properly or is it risky? Thanks!!
AJBert 07-22-2017 07:47 PM
The ZR2 sits about 3 inches higher and about 4 inches wider than the stock Blazers. They also have different mounting points on the frame and a different frame. Pretty sure you can not swap the CV axles.
newguy 07-23-2017 05:33 AM
Dont believe its high rider, think its higher WIDER. and yes it wont make you truck higher, it will just look funny because your tires will be wider
El_Beautor 07-24-2017 01:59 PM
Like AJBert said, the CV axles are not compatible between the ZR2 and regular Blazers.
newguy 07-24-2017 02:06 PM
Yes, front axles will not fit
