-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   growling in the front (https://blazerforum.com/forum/steering-suspension-drivetrain-36/growling-front-71833/)
curt henson Jun 30, 2012 09:17 AM
i was out four wheeling and when i was done i took it out of four wheel and went in revers to unlock everything. when i drive forword its making a growling sound in the front end. cv joints look good. IM LOST, its a 2000 blazer
abig84 Jun 30, 2012 09:56 AM
could be a wheel bearing gone bad. thats the typical sound for that. or maybe the front end is stuck engaged somehow
curt henson Jul 4, 2012 10:36 PM
growling in front end
i didnt replace the wheel bearing yet. the front end growles in 2 wheel drive. you put it in four wheel and the noise goes away. is the front end locked up. how would you disengage it.. this thing is driving me crazy. could it still be the wheel bearing.
aa21830 Jul 5, 2012 11:12 AM
Sounds like either: 1) the vacuum switch for the 4WD actuator under the battery tray is stuck upen, thereby causing constant vacuum and the actuator constantly pulls on the cable that locks the hubs; or 2) the cable is stuck and not moving back to its "unlocked" position.
I'd pull off the battery tray and see what that actuator and cable are doing.
