-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   HELP ASAP.. Torque specs... (https://blazerforum.com/forum/steering-suspension-drivetrain-36/help-asap-torque-specs-26597/)
livinterror 01-15-2009 12:10 PM
I need to know what is the torque for upper and lower control arms, upper and lower ball joints and the half shafts on a 1999 Blazer 4wd. Thanks Help me ASAP THANKS!!
livinterror 01-15-2009 12:18 PM
RE: HELP ASAP.. Torque specs...
I also need to know how tight do I tighten the tie rods? Please help me so I can get this finished!!
THANKS in advance!
swartlkk 01-15-2009 12:19 PM
Control Arm - Upper = 85ftlbs, Lower = 81ftlbs (do not know why there is a difference)
Ball Joints:
- To control arm (small bolts) - 17ftlbs
- To steering knuckle - Upper = 61ftlbs, Lower = 79ftlbs
Axle Retaining Nut - 103ftlbs
Tie Rod to Steering Knuckle - 39ftlbs
In the future, please try the search function. Also, please edit your post to add more information rather than consecutively posting.
livinterror 01-15-2009 12:25 PM
thank you....
8baller 03-21-2019 10:05 AM
Ball Joint To Steering Knuckle79Ft-Lbs948In-Lbs107.11N-mYears:1995-2004Note:Gen II - 2WD - FRONT LOWER Balljoint to Steering KnuckleType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle61Ft-Lbs732In-Lbs82.7N-mYears:1995-2004Note:Gen II - 2WD - FRONT UPPER Balljoint to Steering KnuckleType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle79Ft-Lbs948In-Lbs107.11N-mYears:1995-2004Note:Gen II - 4WD - FRONT LOWER BalljointType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle61Ft-Lbs732In-Lbs82.7N-mYears:1995-2004Note:Gen II - 4WD - FRONT UPPER BalljointType:Dim:Length:Head: NutGrade:
swartlkk 03-21-2019 10:15 AM
*Thread Closed* - This thread is 10+ years old and you didn't provide any new information. Good Job!
