-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   hheellpp (https://blazerforum.com/forum/steering-suspension-drivetrain-36/hheellpp-37301/)
plcboy416 Nov 24, 2009 09:38 PM
hheellpp
why does my 00 blazer sag on he passenger side sag. its got a new torsion bar an is adjusted all the way up just to sit kinda right. when i hit the brakes that side drops instantly. PLEASE TELL ME WHY!!!
oisinirish Nov 24, 2009 10:11 PM
Hopefully someone can come and move this for ya to a more relevant section.
ABN31B Nov 24, 2009 10:34 PM
^^^ lol ^^^
when was the last time you took a peek at your shocks?
Ball joints?
Tie rod ends?
00 blazer what? 2 dr 4 dr zr2? lowered lifted stocker?
did you do your own t-bar swap or did a shop do it?
are you mechanical or a car noob?
any pertenant info you can share will help you get a more direct and tailored answer. DONT POST THIS SAME QUESTION AGAIN, but this kind of thing would fit better in another part of the forum, like suspension tech for example. use the are descriptions to help you find the right fit for your question.
was the vehicle involve in an accident? are you the original owner? why did you swap the bar? any chance you used an "indexed" key on the new t-bar?
Fill us in yo.
Welcome to the forum.
rriddle3 Nov 24, 2009 10:36 PM
*moved to 'suspension, steering & drivetrain'*
swartlkk Nov 25, 2009 06:41 AM
Something is not right in the suspension if you have replaced the torsion bar and it did not change the ride height. I would suspect a bent/broken lower control arm.
plcboy416 Nov 25, 2009 04:21 PM
i changed the torsion baar cause it sagged an it does the same thing its been to two shops an none can tell me why. shocks r bran new also. im not sure but i dont think it was ever in an acident. the garge said they cant see any think thats broke bent or binding so im not sure whats goin on?
jstutzman Nov 25, 2009 05:49 PM
If it is dropping when you hit brakes, maybe you got a bad shock. New one on left is stiff becuase its new and maybe new(broken one) on left is dead. Just a thought but if its dropping when you hit brakes, that is the only thing i can think of.
swartlkk Nov 25, 2009 07:33 PM
A shock won't cause the suspension to dive while braking. The change is too gradual.
It is definitely something wrong with your suspension.
