-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   High speed shake or vibration (https://blazerforum.com/forum/steering-suspension-drivetrain-36/high-speed-shake-vibration-45909/)
walleye seeker Jun 18, 2010 06:19 PM
First i will give the history on this 98 blazer 4wd 245,000 miles . I just bought this truck a week ago knowing it needed front end work and tires so here is a list of what i replaced.
Both front Axles new ones advance auto
all 4 ball joints
inner outer tie rods
both front wheel bearings
front end alignment
4 new general grabber tires
new brakes all the way around.
new shocks all the way around
Now here is the problem truck drives straight as an arrow , brakes are perfect no pulsing no steering wheel shakes. drives pretty smooth up to about 50mph then i start to get a vibration in the front and it continues to worsten at 75mph the truck is shaking pretty hard .
what should i be looking at next i was thinking a seized u joint any other suggestions.
monti72 Jun 18, 2010 10:54 PM
i would try the u joints...but i would also look at the steering stabilzer not sure if you changed that...
