i need lift
my 02 zr2 has a saggy rearend i have a set of 2inch lift shackles for it but i cant get the spring and frame bolts out of the stock shackles i used the forum ideas about hammering them and using c clamps but did not budge the bolts at all and ive considered cutting the bolts but i hear new bushings have to be pressed in anyone have any ideas
I didn't press my bushings in and they have been holding strong for almost a year now. A better way to solve your sagging rear end that doesn't require removing the shackles is to get an add-a-leaf kit. putting longer shackles may help for a while but your leaf springs are still being strained too much. With an extra leaf it helps the other springs to have less pressure and lifts your truck back up. add-a-leafs are about the same price as a pair of shackles.
the shackles i have already and i have considered a addaleaf i need about 3.5 inches total in the rear for it to be level so maybe i should add the spring kit also im just frustrated with these shackles but thanks for info
I agree with the add a leaf. My bolts where so siezed that i had to drill out the rubber bushing around the bolt after i cut the bold head to pound them out then i had to die grind through the outer sleve to get it out of the spring so point of the story dont get frustrated it took me about 2 hour a corner to get my shackles in :) well worth the [email protected]?#&*!!!!!
Pull out the torch and melt all that rubber out and just beat the hell out of it. They will come out eventually mine were the same way
Originally Posted by Supaman
(Post 364598)
only bolt that gave me a problem was drivers bold through the spring, managed to get the top one out to lower the leaf and pounded with a sledge untill it came out. |
Originally Posted by 69chevelle
(Post 364842)
hmm burn/torch rubber that sits right beside the gas tank... good idea...
Dan where u located at in Indy??
(Post 364842)
thank you all for the info im gonna tackle my shackles on sunday for the third time this time a sawzall in hand if i cant get them out im cutting them out lol
| All times are GMT -5. The time now is 07:54 PM. |
