Idler Arm
Hi guys,
I have a steering issue but we call items different names in the UK. I have really stiff steering only turning right, my mech and I were under it today he told me it was the 'linkage from the steering bottle to the track rod end', it has a grease nipple and we squeezed some in and it oozed straight out the bottom indicating that it is worn out.
I don't know the name of this arm in the USA other than it may be an idler arm but I could be very wrong.
Please help
Please help
pitman arm connects the steering box to the centerlink
here is a basic picture
http://streetseen.vi/forums/attachme...2&d=1329959080
While you're under there you should also look at everything. Idler arm, pitman arm, lower ball joints, rag joint. All the things that wear out on these vehicles.
Check the drive shaft (prop shaft) for grease nipples as well
I think a quality grease would make a big difference. I have been using the cheap stuff and it seems to be very fluid. I'm starting to wonder if I should switch to the high-temp tacky red grease for all future parts. Just my $.02 on steering parts maybe lasting longer with better grease.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
kornphlake
Dec 18, 2006 02:18 AM
