Installing an ignition kill switch on 4x4 blazer
Old Dec 11, 2007 | 05:11 PM
oddbirdman's Avatar
oddbirdman is an unknown quantity at this point
Default Installing an ignition kill switch on 4x4 blazer
ok, so my key is stuck in the ignition, no matter what i do i can't get it to come out, there is no hole underneath the ignition switch where the release is supposed to be... i want to install a kill switch because there is no other way to cut the power to the vehicle other than pulling one of the spark plug wires, i have my heart set on a kill switch so if anyone can tell where abouts i should place it in the electrical system it would much qappreciated
1993 Blazer 4x4 3.4l Vortek (Tahoe)
Old Dec 11, 2007 | 05:14 PM
drperry's Avatar
Default RE: Installing an ignition kill switch on 4x4 blazer
Cut power to the ignition switch power wire...
Should come out somewhere under the steering column.
Since you have a 1st gen, though, it shouldn't be that bad to change the ignition cylinder... Heck, Canadian Tire sells 'em! lol.
Open the steering column to find the "hot" wire that supplies power to the key, and that's the one you want to put your switch on to.
Old Dec 13, 2007 | 07:19 PM
oddbirdman's Avatar
ok, i cut every wire that is coming out of the steering column and the damn thing is still running, now what!??
Old Dec 14, 2007 | 05:00 AM
drperry's Avatar
Either pull the ECM fuse, or the coil fuse, the fuel pump relay or fuse, or injector fuse...
Old Dec 14, 2007 | 08:01 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
There should be a thick red wire, Im not sure what gauge in the newer vehicles but it comes INTO the ignition switch, you use that wire and splice a Heavy Duty 30A or better toggle switch into it. Just dont cut it short you need to make a kill loop with it in order to turn it on again.
I have a haynes laying around let me get some **** done and ill look at the diagram and PM you the info if not the diagram with notes itself.
Old Dec 17, 2007 | 05:46 PM
RegSo's Avatar
RegSo is on a distinguished road
yeah a kill switch will be pretty rad to have, would definitely appreciate more info myself
jatkins3983
May 28, 2024 11:15 PM
jaked up
Jan 7, 2012 11:25 PM
jaked up
Sep 15, 2011 09:45 PM
yarinzim
Sep 13, 2010 09:37 AM
ATP
Nov 3, 2008 06:34 AM
