-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Intermediate Shaft Won't Go Back On. (https://blazerforum.com/forum/steering-suspension-drivetrain-36/intermediate-shaft-wont-go-back-100221/)
Backuplegion 09-06-2019 08:39 PM
Just changed all the spark plugs and wires on my 1996 GMC Jimmy 4x4 and I took the bottom of the intermediate shaft off to get to spark plug 3 and now even when the splines lined up correctly it won't slide all the way on. As of right now I have it tightened down about half of the area it is supposed to connect to. A hammer won't even bring it down. I went for a drive to see if it would slide off immediately but it works normally in it's current state.
Tom A 09-10-2019 07:25 PM
You did take the bolt out before you put it back on, right?
Backuplegion 09-11-2019 01:15 PM
Yes I did. What I ended up doing that worked is heating up the part of the shaft that compresses prying down on it with a crowbar and tapping the rag joint with a hammer. I think it just had trouble extending back because it is rather old.
