-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Leaf springs and Shocks (https://blazerforum.com/forum/steering-suspension-drivetrain-36/leaf-springs-shocks-102240/)
Cimmerian 08-30-2020 11:05 PM
I tried searching the forums but either I'm getting old and blinder (likely) or just not using the search function correctly. Anyway,to get to my question :
I have the 2.5 in Rough Country lift on my 2000 LS 2dr 4x4 Blazer. I want to replace the leaf springs, spring bushings, and get four new shocks since I think the ones that came with my lift kit are shot.
I know having the lift kit in the mix complicates matters, so I don't know which brand/part numbers to get. I was looking at getting all Bilstein shocks but apparently I can't use their regular Blazer ones with the lift kit? Can you guys give me a hand with manufacturers and part numbers? I'm looking for heavy duty stuff since I live in a rural area and there are lots of trails and unpaved roads. Thanks!
EDIT :
I have confirmed that ZR2 OEM Bilstein shocks do work on regular 4x4 Blazers. Part numbers are :
The front shocks, 24-014120
The rear shocks, 24-018197
These are Bilstein B6 4600 shocks.
Tom A 08-31-2020 12:49 PM
The Bilstein 5100 shocks are fantastic, so don't give up on them yet. I just tried to find a part number with no luck, but you can probably send an email to Bilstein and see what they say.
Cimmerian 08-31-2020 09:19 PM
Thanks, Tom. I'll definitely email them about it.
Cimmerian 09-01-2020 10:17 AM
So it turns out Bilstein no longer makes their 5100 shocks for Blazers, and no longer makes shocks for lifted Blazers. Any other options?
Tom A 09-01-2020 10:39 AM
Well, that explains why they're so hard to find.
Cimmerian 09-11-2020 12:37 AM
So I contacted Bilstein, KYB, and Rancho. None of them make front and rear shocks for a lifted Blazer.
Any ideas, anyone? I really don't want to get another set of Rough Country as they blow out fairly soon.
Tom A 09-11-2020 12:17 PM
Download Skyjacker's 2020 Catalog. It has all their shock specs (starting on page 214) so you can find them by length and mount type. It's a little tedious, but might be your best option.
DonL 09-11-2020 02:54 PM
Thanks for this... I've been dragging my heels with finding replacements, and have been thinking about going this route.
saves me the search :D
Tom A 09-11-2020 03:34 PM
No problem. I've seen something similar from Pro-Comp, but I can't seem to find it right now.
*EDIT*
Pro-Comp actually lists them by application (for my year, anyway, but yours should be the same). They show the stock length for a 2 inch lift, and this is what they show for a 3 inch lift.
https://cimg4.ibsrv.net/gimg/blazerf...95687c5d69.jpg
DonL 09-11-2020 09:25 PM
This is awesome.... your a saint...
while on the subject, do you have any recommendations for a leveling setup for towing heavy trailers? My camper pushes 4k lbs when loaded, and I sit backwards hot rod lol...
I need to redo my leafs and get new absorbers, so I've been following this thread closely lol...
