-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Left front differential seal and bearing replacement (https://blazerforum.com/forum/steering-suspension-drivetrain-36/left-front-differential-seal-bearing-replacement-97729/)
christine_208 09-09-2018 04:55 PM
Hi all,
Well, I've determined that at least I will need to replace the seal/cover plate on the left side of my front differential on my 1999 Blazer LT. I've even found the part number (12471587). https://www.tascaparts.com/oem-parts...Y2LWdhcw%3D%3D
What I would like to know is since I'll have the whole left front suspension apart to replace the seal, should I also replace the bearing? I found a video (link below) that made me think it is worth doing. Also is that I have a leak at the seal evidence enough that the bearing should be replaced too? I did feel a little bit of wiggle, hardly any at all, but there was more than on the other side.
Finally, if I should replace the bearing, any advice on the procedure and does anyone know the part number? I've been having a very hard time finding what that part number would be.
G0LFADD1CT 09-09-2018 06:01 PM
Not to change the subject but I checked out the website link you posted and it's pretty good. I found things I couldn't find elsewhere. Thanks!
DonL 09-09-2018 06:17 PM
If it's a cheap repair, I would do it all at once. Save having to tear apart twice, just in case.
christine_208 09-09-2018 07:17 PM
Yeah, that is my logic. However, I don't want to mess with anything that I could mess up and which to fix would be more of a hassle! :)
christine_208 09-10-2018 12:44 PM
Quick update:
I called the local Chevy dealer and here is (what should be) the part number for the left output bearing: 26053326
