LiftKit question!
LiftKit question!
I'm wanting a 3" Suspension lift on my Blazer... I'm not big on lifts or anything, How big lift should I get, And What size tires? How much Do you think it would cost?
not sure if they make a 3in lift or not but either way you will be going through front end parts like crazy. The max you can lift the front is 1.5in without having any issues. Then for the rear just get a set of shackles. So it will cost you around 60 bucks total. Since you can lift the front by cranking the tbars. Which is the exact same thing all the 2in lifts do. So you are saving a few hundred bucks. Do a search for tbars and shackles and you will find out how to do it.
https://blazerforum.com/forum/lifting-tech-44/start-here-lift-kit-list-16186/
Check out the lifted section for all your answers. Most of the typical lift question have been asked and answered in that section.
2001Blue
Lifting Tech
01-01-2011 07:15 PM
98Ltblazer
04-11-2010 11:34 PM
Numba1Sean
05-06-2009 11:48 PM
Chadoo951
05-06-2007 07:01 PM
