-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Link to reset four wheel drive buttons (https://blazerforum.com/forum/steering-suspension-drivetrain-36/link-reset-four-wheel-drive-buttons-27085/)
kattie0002 Jan 31, 2009 10:43 AM
I know there is a thread on some where I have been searching for a while for it , Can someone help .It is for a 2000 Chevy Blazer S10 4x4 I need to no how to reset the 4wheel drive on it ,I know it said something about taking the battery cables off to reset can some one confrim this or tell me how to do this the right way , Thank you
kiwiblazer Jan 31, 2009 02:49 PM
RE: Link to reset four wheel drive buttons
I don't think there is a way to "reset" the 4x4. You need to explain the symtoms & someone will give advice or point you in the right direction. As I understand it, disconnecting the battery will only erase/resetany codes in the computer making it difficult to diagnose the problem. It may just be a faulty switch on the dash. You may need to check for leaks in the vacuum lines first. This I think is the most probable cause. From there it gets tricky, trust me, I've just been throught it & ended up replacing the t/case. Thank "whoever" for extended waranties. LOL. Then there's the vacuum actuator (under the battery), the TCCM (in the pass. kick panel), the transfer case switch (on the t/case) & finally the front axle. Hopefully yours is a simple problem.
kattie0002 Jan 31, 2009 04:37 PM
We have changed all vacuum leaks ,changed out the value on the transfer case that goes to the vacuum it was froze in place , when we replaced the bearings and hooked up the cables we thought that maybe it would have to be reset for the 4 wheel drive lights to work they stay yellow maybe it does need a new switch , we also freed up the actuator I think that is what it is called ,thats why I was wondering if we took the battery cables off it would reset ,Let me know on this and thank you
