-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Lower front shock bolt (https://blazerforum.com/forum/steering-suspension-drivetrain-36/lower-front-shock-bolt-85321/)
Izzy207 04-10-2014 11:20 PM
The front passenger side shock was replaced but it seems as if the lower bolt is small. There is a little bit of play when I move the shock around.
Here is what I need to know:
What is the bolt size that is used?
Are there bushing that needs to be replaced between the shock and the control arm that it attaches to?
Thanks for all the help
LeWhite 04-11-2014 12:08 AM
Two wheel drive?
rockp2 04-11-2014 12:13 AM
There's a bushing in the end of the shock where the bolt goes thru, but besides that there isn't a bushing between the shock and the lower control arm. But then again...I have no idea what kind of vehicle, year, etc you're referring to.
Izzy207 04-11-2014 12:23 PM
Year: 1999
Train: 4WD
rockp2 04-11-2014 01:32 PM
Originally Posted by Izzy207 (Post 624352)
Year: 1999
Train: 4WD
OK, then my post above applies.
TonyZR2 06-25-2018 11:36 PM
1 Attachment(s)
Mines 2nd Gen. But if this info helps anyone.:
Front lower shock bolts are... Gr 8 met 12mm wide x 1.75mm spacing x 75mm long, according to the GM Parts dude. Strange, mine say 9.8......and I still rounded the corners a bit, using a 6pt socket. I still can't get it off. I've KYB Mono's to put on...ughh.
TonyZR2 07-16-2018 12:38 PM
By the way...... got it off. I put epoxy in the end of an impact socket (cleaned bolt head with solvent first). Then clamped the socket over the bolt for 24hrs. Used my breaker bar.....and it worked! Kept the socket from starting to slide off, and actually got the damn thing off.... after three days trying. I was using a 6pt socket at first and it still would slip off and rounded the corners. Even salvaged the impact socket by chipping the epoxy out with a flathead screwdriver. And the middle threads of the bolt got messed; managed to "fix" that, too. By putting it in Visegrips, dousing it in silicone Liquid Wrench, then sticking it over the edge of the curb, standing on the grips...... and just reaming the nut back on with my socket wrench. After about three times on and off, the nut would go on without much difficulty. So was able to use the same bolt. I put it back, on the top side this time. KYB MONO MAX's! #¥{& YEAH! :icon_banana:
