lsd diffs
hi , just bought my first chevy blazer ,should have bought one years ago ... to sort my confussion . does my 2000 blazer LT have L S D diff,s front and rear or not . thanks .
If you go to this website compnine.com and type in your VIN # it will tell you anything you want to know. You are looking for the G80 code. You can also check in your glove box and it will tell you if you have one.
thank you for that , downloaded the build sheet for my blazer ... great site ... cheers
right rear indicator not going
Hi guys , the right rear indicator has stopped working on my 2000 blazer L T ...Have taken it out and stripped the loom back to where it goes thru the rubber grommet into the body work and have no power in the wire to the bulb . it has good earth grounding and bulb ok . The other two right hand flashers(fnt guard and fnt bumper ) are still going .... any idea where to start looking for fault . thanks . Kiwi Fan ..
hi,
could you tell me if it has LSD?? i could not download the site
Originally Posted by kiwi fan
(Post 443263)
Check your glovebox sticker, it should be there.
| All times are GMT -5. The time now is 03:50 AM. |
