Need new torsion bars, can't find them anywhere :(
I can not for the life of me find any new torsion bars, anywhere, I can't even find NOS. I have 208k miles and my truck feels like driving a bowl of cereal. I'm redoing the whole suspension, but the one thing I can't find anywhere are new torsion bars. If anyone knows where I can find them, stock, aftermarket, or of other model torsion bars that fit etc. please let me know. I'm almost tempted to find some
https://cimg5.ibsrv.net/gimg/blazerf...eff37446fd.jpg PFA, the leafs are old and tired too, but I can get replacements for those readily... in a junkyard with low miles, but they're still springs that have been in compression for 2 decades. |
https://www.gmpartsgiant.com/parts-l...ion-front.html they still list a couple, most places are sold out and they are discontinued. These may or may not be correct for your suspension code, you’d have to check. |
Originally Posted by CWBDDSPC
(Post 700497)
https://www.gmpartsgiant.com/parts-l...ion-front.html they still list a couple, most places are sold out and they are discontinued. These may or may not be correct for your suspension code, you’d have to check. Edit: I just looked, and the area is smudged, but I'm fairly certain I have 7WJ. So I guess the stiffer ones on that page must be the ZR2 bars, which makes sense. In any case, it appears I'm still **** out of luck unless I find some NOS, going to hit up a stealership tomorrow and see if they can wrangle anything up...I still can't believe there aren't aftermarket ones available, these trucks are popular as hell and there's still quite a few on the road. I have like 4 different brands to choose from for leaf springs, but not 1 for torsion bars. |
Here’s an application guide... sorry it won’t help you find new ones though.... https://cimg3.ibsrv.net/gimg/blazerf...e38125dc6.jpeg |
Yeah, your best bet is to find some used ones from a low mileage ZR2, or get super lucky and find somewhere that carries them. Even though the 4-door Blazers were the heaviest they very often came with the softer torsion bars because they were targeted as family or granny vehicles, not as HD work horses. Those customers want soft smooth rides. Here's the part numbers for all the various torsion bars that came on S-series trucks:
Originally Posted by jsmz
(Post 277457)
now that ive said that here is the list of bars gm made Part Number Bar Dia. NOM Torque LH 15956501 26.63mm 1052 RH 15956502 26.63mm 1052 LH 15956503 27.94mm 1276 RH 15956504 27.94mm 1276 LH 15956505 29.36mm 1450 RH 15956506 29.36mm 1646 LH 15956509 30.69mm 1883 RH 15956510 30.69mm 1883 LH 15956511 32.51mm 2305 RH 15956512 32.51mm 2305 ... |
I never realized how hard it was to find t bars. But now that I do know, I have this urge to replace mine 😔
Originally Posted by cleburne red
(Post 700612)
I never realized how hard it was to find t bars. But now that I do know, I have this urge to replace mine ��
Welp, I've pretty much given up on finding new torsion bars, after giving it some thought, I think what I might do is an SAS. I was going to rebuild my whole suspension and steering anyways, and I was also planning to lift it, and wanted a front LSD or locker. I think for me at least this might be the best solution. There is a lot less parts to wear out, there is no shortage of leaf spring options, it will be stronger, I will have options for an LSD or locker, etc. I still can't believe nobody makes torsion bars for the S-series it really blows my mind. I still see lots of them on the road, and I know people love them. And compact trucks/SUV's(not to be confused with crossovers, aka overgrown station wagons with slightly more ground clearance) aren't even made any more, so I doubt I'm the only one who plans to hang onto theirs. I love the rugged simplicity of it, and it may be on the small side, but still manages to do everything I need it to. On the note of SAS swap, I'm still trying to figure out what my options are for donors, I found a pretty good list for the Dodge/Jeep products and what axles they have, but I still haven't found one for Ford or Chevy. I think I'm going to go with a Dana 44. I'll probably swap for a manual T-case too, the electronic ones are so unreliable...not what I want in my 4x4...Looking to see what's in junkyards atm, found an 87 2500 4x4 in a pick and pull, but not sure what it has, trying to figure that out currently. I do appreciate the info about parts numbers, but in the end it doesn't do me any good if nobody has any of them...I considered buying the ones I had found, but if anything I want stiffer bars, not softer ones, that's the whole reason I want to replace them anyways...at 208k this old truck is sloppy.
Earlier today I found a cross reference for the torsion bars; RPO codes, part numbers, and max torque rating. This is just one of the pages https://nemigaparts.com/cat_spares/e...t/06/tt06-546/
You cannot buy parts from this place but they have the best exploded diagrams I've been able to find: https://nemigaparts.com/cat_spares/epc/chevrolet/ From the first page with identifying note: TT06-546 12/15/2006 (there are three pages with torsion bars so you might have to look at the others) 007Bar, frt tors(max load 1404)(w/suspension)(code 6wh) - lhST1 SUSP(6WH)0115956503-- 007Bar, frt tors(max load 1404)(w/suspension)(code 6wh) - lhT1 SUSP(6WH)0115956503-- 007Bar, frt tors(max load 1404)(w/suspension)(code 7wh) - rhST1 SUSP(7WH)0115956504-- 007Bar, frt tors(max load 1404)(w/suspension)(code 7wh) - rhT1 SUSP(7WH)0115956504-- 007Bar, frt tors(max load 1704)(w/suspension)(code 6wj) - lhST1 SUSP(6WJ)0115956505-- 007Bar, frt tors(max load 1704)(w/suspension)(code 6wj) - lhT1 SUSP(6WJ)0115956505-- 007Bar, frt tors(max load 1704)(w/suspension)(code 7wj) - rhST1 SUSP(7WJ)0115956506-- 007Bar, frt tors(max load 1704)(w/suspension)(code 7wj) - rhT1 SUSP(7WJ)0115956506-- 007Bar, frt tors(max load 2071)(w/suspension)(code 6wk) - lhST1 SUSP(6WK)0115956509-- 007Bar, frt tors(max load 2071)(w/suspension)(code 6wk) - lhT1 SUSP(6WK)0115956509-- 007Bar, frt tors(max load 2071)(w/suspension)(code 6wk) - lhT1 SUSP(6WL)0115956509-- 007Bar, frt tors(max load 2071)(w/suspension)(code 7wk) - rhST1 SUSP(7WK)0115956510-- 007Bar, frt tors(max load 2071)(w/suspension)(code 7wk) - rhT1 SUSP(7WK)0115956510-- 007Bar, frt tors(max load 2071)(w/suspension)(code 7wk) - rhT1 SUSP(7WL)0115956510-- |
1 Attachment(s)
Right so I got into this and here are the part numbers, RPO codes, part numbers, maximum torque, and application notes for all of the torsion bars I could find at the nemigaparts.com website. See the attached file.
(Post 700640)
The heavier bars really are hard to find. I got lucky twice: I have a set of the 30.69mm torsion bars from a ZR2 pickup that I ended up not installing on my Blazer because I couldn't free the factory bars from the keys before I sold the Blazer. I was about to install them on my newer crew cab Sonoma when I found out that the previous owner had already upgraded the torsion bars and leaf packs through the dealership a couple years before I bought the truck.
Originally Posted by Hunterturner6
(Post 700934)
Does this mean you still have them sitting around your garage? 😉 |
(Post 700965)
Kinda, yeah, but I promised them to my brother two years ago for his Sonoma. He's just never collected them.
