New add-a-leaf kit...
Old Jul 28, 2008 | 07:57 PM
El_Beautor's Avatar
Default New add-a-leaf kit...
So I just got in my new add-a-leaf kit and went over to a friends shop this evening to put them in. As we are unloading the factory springs, we notice something very disturbing. The Main leaf-spring is cracked almost all the way through. Then when we try to put it back together (without the add-a-leaf) it snapped completely. Now I have to call the wreckers first thing in the morning to try to find a new one. I'm without a ride tonight. Not too happy about that. Hopefully things go smoothly in the morning.
Old Jul 28, 2008 | 09:58 PM
ZR2nut's Avatar
ZR2nut is an unknown quantity at this point
Default RE: New add-a-leaf kit...
Look on the bright side.It was a good thing you found it.Actually not that uncommon.You may be better off with a set of aftermarket springs.Now would be the time to replace them.
Old Jul 28, 2008 | 10:55 PM
Chances are, if your back end is sagging, it isn't because the springs are reverse arched, its because the main leaf is broken. I have seen quite a few s-series with this problem.
Old Jul 28, 2008 | 11:12 PM
El_Beautor's Avatar
Now you tell me.... At least the other side looks ok. I wouldn't mind aftermarket springs but the budget is kinda tight right now.
Old Jul 29, 2008 | 02:48 AM
Blazin_Jason's Avatar
Took my blazer springs out and the second leaf was broken in 2. Took my jimmy springs out and one main was cracked but not yet broken. 2 trucks 2 bad springs.
cory renner
Lifting Tech
Feb 7, 2013 08:50 AM
xachman17
Lifting Tech
Jul 15, 2012 03:04 PM
99LS4x4ryanlw
Lifting Tech
Sep 29, 2011 02:13 PM
PaulO2288
Apr 21, 2011 12:25 AM
two1nine
Suspension Tech
Nov 27, 2009 07:09 PM
