PLEASE help!!!!
Old Apr 10, 2012 | 07:46 PM
rfwago11982's Avatar
rfwago11982 is an unknown quantity at this point
Default PLEASE help!!!!
I changed my drivers side cv axle assembly today because the shop I had ny tuneup changed my cv joint n somehow put a whole in my rubber cup anyhow I changed it went well except there is a slight squeak when I hit a bump could it b because I over tightened my ball joint PLEASE HELP
Old Apr 10, 2012 | 08:49 PM
warthogdriver's Avatar
Look up the torque specs and by chance did you grease the steering parts you worked with?
You need to put in what your ride is and year...would help with more direct info
Old Apr 10, 2012 | 09:24 PM
It's a 1997 4 door blazer lt I greased everything its not a bad squeak just a lil quick squeak when I hit a bump it doesn't go squeak squeak squeak just short not sure it drives fine 4wheel works fine no jolt or squeal then only when I hit a bump I don't understand it
Old Apr 10, 2012 | 09:27 PM
xgiovannix12's Avatar
shocks?
Old Apr 10, 2012 | 09:31 PM
Did I over tighten my lower s??hock bolt
Old Apr 10, 2012 | 09:37 PM
no but its possible the shock is squeeking
Old Apr 10, 2012 | 09:42 PM
It only does it why ur moving and it didn't happen prior
It wasn't nething I did my daughter slammed my door while my truck was in air it was the hinge a lil grease n fixed
Atleast I think n hope
Idk I figure ill make sure tom but I think I got it
Last edited by rriddle3; Apr 10, 2012 at 11:40 PM. Reason: COMBINING CONSECUTIVE POSTS
Old Apr 10, 2012 | 11:45 PM
rriddle3's Avatar
*Moved to 'Steering, Suspension & Drivetrain'.*
What was the reason for making one post after another when it should have all been in one - trying to increase post count? If you need to add to a post before anyone else has replied, please use the 'edit' button.
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
