Plumbing Rear Disk Brakes
Hello. I've acquired a rear axle with disk brakes from the junkyard, and looking for info on plumbing the system.
I have a 97 Blazer LS 4x4, so the proportioning valve is in the ABS Module. Do I need to do anything special to the hydraulic system to make these work? Will I need to get an ABS module from a truck that has disc brakes from factory, or will the disk brakes be more-or-less plug and play? Thanks! |
Plug and play for the hydraulics. E-Brake hook is different between drum and disk brakes. I converted my 89 S15 from rear drum to disk brakes. I used the disk brake cable wire inside the drum brake cable housing. I accomplished this by cutting off the cable stop and running the cable through the disk brake wire through the drum brake cable housing and crimping on a new cable stop to connect the cable to the E-Brake equalizer.
Below is my write up of my rear drum brake to disc conversion. There are 2 ways to connect the E brake. One is using a disk cable inside the drum housing and crimping a new cable stop on or make or have an adapter made for connecting to the rear actuator. there was person making the adapters on this forum but I do not know if he is still doing it.
https://blazerforum.com/forum/1st-ge...on-done-94933/ |
Sean was custom fabricating the adapters in the pic below to connect to the disk brake actuator. I do not know if he is still doing this but you could email him. This was on the S10 Forum
hi_im_sean9" strait pipes...Joined Jun 21, 2011 2,920 Posts Discussion Starter • #101 • Aug 15, 2017 The first 5 of you have PMs (except r6chevelle). Theyre boxed and ready to go. Price from now on is $50 plus $8 shipping, and everyone gets a 3d printed keychain! I ran out of steel, ill order more this week and start another batch for the rest of you. Id like to say a couple weeks, but lol, you know how that goes. http://i222.photobucket.com/albums/d...g?t=1502766970****ty website to be updated soon! http://sadfab.com/ |
| All times are GMT -5. The time now is 07:41 PM. |
