-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   posi doesnt work (https://blazerforum.com/forum/steering-suspension-drivetrain-36/posi-doesnt-work-21559/)
NVANZEE 06-26-2008 09:38 PM
posi doesnt work
i looked up the RPO's and found out that i have posi. The bad thing is that it doesnt work. I think it is powered by vacuume correct me if im wrong but were does the line connect. im assuming that i have a bad line. if anyone could tell me what to do it would help alot out on the trails.
TripleBlackBlazer 06-26-2008 10:12 PM
RE: posi doesnt work
RPO code G80? It is not vacuum controlled. How did you test to see if it works? They lock up if they see an axle speed difference of 20mph through a weighted clutch type of mechanism. It is purely mechanical.
NVANZEE 06-26-2008 10:20 PM
yes it is G80 and i have been stuck a few times and the wheel with out traction is always the one spinning
swartlkk 06-27-2008 06:06 AM
Could be busted. You'd need to open up the diff to determine if it is.
Have you owned the truck since new? Its also possible that someone swapped in a different rear end.
NVANZEE 06-27-2008 06:24 AM
no i have only had it for about 8 months
WolfPack 06-27-2008 11:32 AM
I'll take your G80. Being busted and all...free? :D
