Rattling noise at 35mph+
Old Jun 7, 2020 | 07:37 PM
Micah Ransler's Avatar
Micah Ransler is on a distinguished road
Post
Originally Posted by moosehauler05'blaz
There is a gear in the transfer case With a selector arm In 2WD nothing is used Once you push the 4WD button That arm sets the gear into the other giving you 4WD If you have a bad vaccum leak / encoder You will have the arm only go in half way Chewing your carrier gear (Differential Carrier Gear Kit Front Dorman 600-561) There is no need to buy a whole diff unless its under $100 And you feel like paying extra on labor Myself i replaced the gear And the actulator under the battery Along with the vacuum actuator switch And checked all my Vacuum lines There is Youtube videos for how to remove and install your carrier kit which is simply removing washers in order The gear Then putting the new ones in. in the same order ..If your feeling mighty...buy a new cable too and clean the mounting area
I don't know if I mentioned this earlier, but it makes this noise in both 2WD and 4WD. I don't think it has anything to do with the 4WD system.
Old Jun 18, 2020 | 07:41 PM
Lanak's Avatar
Lanak is on a distinguished road
Default Weird noise in 2wd, so how fast can i go in 4hi?
Originally Posted by Micah Ransler
Let me start by saying that I searched this site for 3 hours and I didn't find my exact problem. So I'm creating a new thread.
I have a 4x4 1999 S10 Blazer. Not sure if this matters, but it's a LS.
There is this really awful rattle coming from somewhere underneath the car. Took it to the shop, and my mechanic said that it was coming from the t-case, and that it needed to be replaced (as well as the encoder motor).
So I replaced them both with used parts from my other blazer, but the noise remains. Also installed new universal joints and front and back driveshafts.
I don't know what this noise could possibly be because I know the replacement t-case and encoder motor are good. Any help would be much appreciated.
Old Jun 18, 2020 | 07:59 PM
It turns out that the rear leaf spring bushings had gone bad and it was causing them to clunk on the frame. Thanks for all the help
nickel and dime
Jan 12, 2013 11:41 AM
goins.joseph@yahoo.com
Sep 29, 2011 07:23 PM
ronkrolock
16
Mar 4, 2010 09:17 PM
Carol023
Sep 19, 2009 01:47 AM
maggierice
Aug 26, 2006 11:00 AM
