rear diff questions?
I found a website that lists all the RPO codes and after I went threw all the codes I know my blazer has the 3.42 gears.( not the ones I was hoping for) I still have no idea what size it is. Whether it is a 7.5 or 8.5 rear any info on how to tell would be great
What's the specs on your truck? Chances are its a 7.5 unless you have a ZR2
Its a 97 4 door 4x4 and does not have the g80 another bummer
2 Attachment(s)
https://blazerforum.com/forum/attach...ine=1379901647
https://blazerforum.com/forum/attach...ine=1379901647 also the axle tubes for the 7.5 are the same size from end to end. the axle tubes for the 8.5 get larger just before the pumpkin. |
The chances of 4 door having a g80 rearend are as lucky that hair will regrow on the top of my head or my psychotic neighbor will move sometime soon.
I have 3:73s and a G80:)
Yeah but did the vehicle come with them gears or did you install them?:icon_worthy::icon_worthy:
Surprisingly they are factory! I even managed to get the full skidplate option:)
I had all 3 of those options on my 4 door as well. Thing was a beast for what it was.
The only way to get the 8.5 10 bolt in a 4 door Blazer is an axle swap from a ZR2. If you go this route, it's pretty easy to do the rear axle. I did mine in about 2 hours by myself in the driveway. Swaping the front diff to keep matching gears is a lot more painful, but possible to do with normal hand tools. My truck came with 3.42 gears too, and I swapped in a ZR2 axle to get the 3.73 gears, wider stance, and the G80 locker.
| All times are GMT -5. The time now is 07:07 PM. |
