Rear differential
Old Jul 29, 2008 | 06:53 AM
hooptyfxr's Avatar
hooptyfxr is an unknown quantity at this point
Default Rear differential
2003 S10 blazer when turning left the left rear wheel drags,to the point of leaving skid marks.The same thing happens when you turn to the right,the passenger rear wheel drags.I don't know what kind of rear end this is but I do have the cover off.it has a couple of small spring loaded levers on one side of the carrier. The carrier moves when the wheels are spun manually,I don't see anything out of the normal.Has anyone seen this? What could be causing this and what do I need to fix this problem??
Old Jul 30, 2008 | 12:00 AM
Chevy Lover's Avatar
Default RE: Rear differential
Try holding one wheel and have someone turn the other. You probably have some broken spyder (pinion or case side)gears broken. Try cleaning the case out with brake parts cleaner and checking for loose metal with a magnet.
Old Jul 30, 2008 | 12:11 AM
WolfPack's Avatar
If he's got the spring levers, its probably the G80...and it's probably grenaded in classic g80 style. The locker should only engage <20 mph...but yours is locked in permanently now [:@]
Old Jul 30, 2008 | 06:16 AM
Brakes hanging up? If everything looks in order in the diff, I don't think it has grenaded. Or at least I would hope you would be able to tell.
Old Jul 30, 2008 | 08:20 AM
WolfPack's Avatar
its just weird that it switches sides..
Old Jul 30, 2008 | 08:53 AM
yeah. Any way that you could snap some pictures of the inside of the diff?
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
MusicMaverick
Apr 21, 2007 02:17 PM
myetman
Apr 14, 2006 01:46 PM
Binz316
Apr 12, 2006 12:55 PM
