Rear differential gear ratio identification
Hello friends out there,
Glad to join u guys on blazerforum. My cousin has just got a 1996 blazer model but we haven't enjoyed the ride as we found out the differential carrier gear have been damaged , We re looking on getting a rebuild kit , but our main problem is to find the gear ratio for that rear differeantial as all spare dealers are asking for it . Would you help if you check on the car vin: 1GNDT13W1TK133395 Thanks a lot Rick, Uganda |
This is the new member introduction area, not a place to ask questions, but since you posted in here, Look in the glove box for the RPO code.
And match what code you have in there with this list GU1 : AXLE REAR, 2.41 RATIO GU2 : AXLE REAR, 2.73 RATIO GU4 : AXLE REAR, 3.08 RATIO GU5 : AXLE REAR, 3.23 RATIO GU6 : AXLE REAR, 3.42 RATIO GV1 : AXLE REAR, 2.73 RATIO GV2 : AXLE REAR, 5.83 RATIO GV3 : AXLE REAR, 3.08 RATIO GV4 : AXLE REAR, 3.36 RATIO GV5 : AXLE REAR, 3.55 RATIO GV7 : AXLE REAR, 4.11 RATIO GV8 : AXLE REAR, 2.72 RATIO GW2 : AXLE REAR, 2.56 RATIO GW3 : AXLE REAR, 2.56 RATIO GW4 : AXLE REAR, 3.31 RATIO GW5 : AXLE REAR, 2.73 RATIO GW6 : AXLE REAR, 3.27 RATIO GW8 : AXLE REAR, 4.10 RATIO GW9 : AXLE REAR, 2.93 RATIO (DUP WITH GU3) G80 : AXLE POSITRACTION, LIMITED SLIP |
*Moved to 'Steering, Suspension, & Drivetrain'*
Thanks Jimmy,
I checked and found out it was G80 now which ratio is that? I will appreciate your response. Rick |
g80 is "posi-trac" not the gear ratio. the ratio should be beside where you found g80
Most likely the gears in your truck will be one of these:
- GU6 - 3.42 - GT4 - 3.73 - GT5 - 4.10 - GU4 - 3.08 As far as I have been able to research, those are the gears that came from factory on the S-series trucks and SUV's. By far the most common were the GU6 and GT4 gears. Like Chris said above, G80 was the posi-trac locking differential and was an option with any of the gear sets. |
what blazers had the GV2 5.83 gears? would that be a good rearend for an ls swap?
Originally Posted by ktjr2
(Post 630137)
according to your VIN
GT4 - 3.73 G80 - Limited slip I have the ability to run them at work ;) |
| All times are GMT -5. The time now is 07:52 PM. |
