Rear End Question
The rear end in my '96 Blazer is going out. Screams while I'm driving down the road. I know what gear ratio I need, being 3.73. What I was wondering is if it will be a simple swap to replace my current drum brake, posi read end with one from a ZR2 that has disc brakes and is posi as well. Or will I have to make a few more changes?
Thanks in advance! |
https://blazerforum.com/forum/general-chat-34/zr2-ed-49901/
this might give you an idea about the zr2 rear end. I would say go with the disk brakes if you are going to do an axle swap. |
if your going to do a disc swap in the back I beleive you need to change the master cylinders/booster as the brake balance is not the same from disc to drum and disc to disc. Don't quote me, but I've read this in many places before. You may be able to get away with just an adjustable proportioning valve, though
Originally Posted by 01vortec
(Post 371769)
is your rear end bad or is it your differential? Because your option with a new diff you could get...
http://www.4wheelparts.com/Drivetrai..._pn=EAT912A317 or http://www.4wheelparts.com/Drivetrai..._pn=EAT162C59A that would be much better than the zr2 g80 lsd, and then the axle wouldn't stick out like a zr2 |
Originally Posted by '96-Dirty4x4
(Post 371859)
Will when I swap the motor out for a 305 carb, though, and get rid of all this computer crap. ;) lol
I prefer the 305. Would get a 350, but I don't think it'll fit in the engine compartment. I don't like all the computer controlled stuff, as well. Plus, my hubby and I can work on carb motors. I also plan to bore and stroke it as well, with larger pistons. Oh, it'll have more bhp than stock. lol Maybe not more than my 4.3, but more than stock. And I sure as hell am not gonna get rid of the 4.3.
(Post 371862)
(Post 371925)
they should have had a v8 option in the blazer... the explorer and durango had that option...
| All times are GMT -5. The time now is 08:07 PM. |
