Rear End Squeaking, Help
For some reason my rear end started squeaking I can't tell where in the rear end it's coming from though. I just replaced the shocks that were blown, but that didn't help. I am thinking it might be the leaf springs? or do I need to grease something in the suspension, or are there some bushing I need to replace? The squeaking is driving me NUTS
Any ideas? I'm going crazy!!!!!!!
It could possibly be the leaf springs
I sprayed the leaf springs with WD-40 and that didn't help any. Did I miss some grease fittings in the rear?
Is it squeaking when you turn or go strait?
I had that problem. I replaced all the rubber bushings with urethane bushings. Get under there and check the rubber for dry rot & dont forget the body mounts.
duckland23
08-12-2012 07:39 PM
blazernoobie
07-13-2009 08:58 PM
stevelknievel
07-17-2007 08:13 PM
