Rebuild starts with my front end NEED ADVICE
I have had my '99 for 10 years, and sounds like I'm one of the few with good luck. Normal wear has worn out the front end, replacing sway bar links, idler arm and will work through rest of it. Should I upgrade the sway bar (with what?). I plan on replacing all bushings, etc. Want to lift the suspension, but not body lifts. Rancho makes lift shocks for the front, but NOT for this. Any ideas. Does cranking the t-bar make a difference. Would like to run taller tires.
Love my truck.
Love my truck.
Love my truck.
Love my truck.
you can crank the t-bars but it will make it ride like a tank and cause a little vibration,but if you don't really care about the ride and like wheeling then go for it but when you do a alignment you wont be able to the caster and camber in at the same time so it's one or the other and i choose caster.
I may crank the t-bar and see if I like it, can always go back. Wish I could use the Rancho Quicklift shocks, but they don't make them for this vehicle
rear just get shackles, cheap enough.
dieseltwitch
05-24-2013 04:43 PM
evlblkwpnz
12-18-2009 08:26 AM
88s10Blazer
12-25-2007 09:29 PM
