Replacing Left Front Differential Output Bearing and Seal
2 Attachment(s)
Hi all,
I thought I'd report on my replacement of the left front output bearing and seal. Starting this spring I had noticed what I had thought was left-over grease covering the upper face of the lower control arm. However I guessed it was actually oil leaking from the front differential. When I checked the level, sure enough it was down a bit. So I decided to look into changing out the seal. After some searching, which was not easy, I did find some references and examples of similar work being done (also on a Safari van). What I realized was that I might as well replace the bearing while I was at it and instead of replacing the seal, I'd get a new cover with the seal already mounted. Like a lot of things on our Blazers, much of the effort is just getting to the part. In this case you have to remove the left front drive axle. Now although some say it is possible to remove the axle without taking off the steering knuckle, for this job you will want to take it out so you can easily get at the axle and differential cover. Parts/Tools Used:
https://cimg8.ibsrv.net/gimg/blazerf...fb2f69aee3.jpgDrive axle partially removed before I realized I would have to also remove the steering knuckle to get it out. https://cimg3.ibsrv.net/gimg/blazerf...fed83c7aaf.jpg Close up of left side of differential with axle removed looking into the differential To start you will want to drain the the oil out of the front drive axle. This is a good opportunity to change it. It is easier to refill with a pump. To remove the cover plate, I found that the upper two cover bolts cannot be reached with a socket. I could have removed them with a combination wrench but I took the opportunity to get a set of metric crowfoot wrench heads for my socket set. This made cracking the top nuts much easier and later allowed me to actually use a torque wrench on them when I installed the new cover. These bolts have 13 mm heads. With the cover off, next was to remove the bearing. A few things to note about the bearing removal and replacement:
https://cimg2.ibsrv.net/gimg/blazerf...604d383b4f.jpg Outer face of bearing showing stamped lettering. This must be installed with this face facing outward. https://cimg5.ibsrv.net/gimg/blazerf...badc7fa942.jpg Inside face of new cover. https://cimg4.ibsrv.net/gimg/blazerf...8296aa46b9.jpg Outside face of new cover. https://cimg6.ibsrv.net/gimg/blazerf...1622473da1.jpgBearing removal tool before modification. https://cimg7.ibsrv.net/gimg/blazerf...1ce210b903.jpg Bearing removal tool mounted in place and pulling commenced. https://cimg8.ibsrv.net/gimg/blazerf...2339e955ef.jpg Modified jaws of bearing puller showing that in addition to shortening them, I should have filed down the parts that extended outward. https://cimg5.ibsrv.net/gimg/blazerf...2465cdd140.jpg New bearing installed. I pre-oiled it as a precaution. https://cimg6.ibsrv.net/gimg/blazerf...cc43904422.jpg Bearing insertion tool. When it was close to being fully in, I took one of the larger anvil heads and mounted it so only the flat face was outward so that for the final taps of the hammer I would not over insert it. https://cimg2.ibsrv.net/gimg/blazerf...9067b20e3b.jpg New cover installed. I used the Permatex flange sealant. I also cleaned the surfaces with brake cleaner to ensure a good seal. The original cover did not have any sealant but this sealant was called for in the GM manual in the steps for rebuilding the front differential and axle. I'm leaving the differential empty of oil for at least a day to ensure it is cured. According to the Technical Data Sheet for the sealant, the part can be returned to service after an hour with no need to only partially tighten and then re-tighten (like with RTV) with tightening to full torque (18 ft-lbs) during assembly. UPDATE 2019-06-03:
Edit: Added GM Service Manual excerpts for this repair. |
Nice work! |
Originally Posted by CWBDDSPC
(Post 696327)
Nice work! |
Good stuff! Thanks for posting all that, I'm doing this same repair soon. One question, what should the torque be for the cover bolts? TIA
1 Attachment(s)
Originally Posted by bigheartedchilly
(Post 710817)
| All times are GMT -5. The time now is 03:29 PM. |
