-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   restricted steering (https://blazerforum.com/forum/steering-suspension-drivetrain-36/restricted-steering-22681/)
2000Blazer4x4 08-20-2008 09:55 AM
restricted steering
Did a tranny swap and I'm thinking this issue has something to do with the driveshafts- mainly the u-joints. As I was backing up to test reverse I spun wheel left and the blazer stopped moving in reverse with the wheel turned - same thing in both directions.
My torque wrench is old so maybe the u-joint caps are on too tight? I'm too cautious to take the blazer on the freeway yet so I don't know if there is vibrational issues at higher speeds yet.
What could be causing this?
swartlkk 08-20-2008 10:03 AM
RE: restricted steering
If it is in 4wd, it will do this. Other than that, u-joint cap tightness will have nothing to do with steering bind.
