-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Rim touches upper arm (https://blazerforum.com/forum/steering-suspension-drivetrain-36/rim-touches-upper-arm-74533/)
89 Blazer Lebanon 10-16-2012 02:31 AM
2 Attachment(s)
I can't turn my wheels to maximum left without having the left front stock rim rub against the upper control arm. (2 pics attached)
I think (not really sure) it all started after I cranked the torsion bars, although it used to happen before the cranking, but only when wheels are locked to max left and down a steep hill.
I also changed upper and lower joints on both sides and have my upper ones flipped (mounted on the the control arms) but I had the previous ones mounted the same way for 3 years.
What could the reason be and what are the fixes for it (keeping in mind that I want to keep my T.B. cranked)?
newguy 10-16-2012 04:28 AM
offset rims, giving you a wider stance. Cragar 3975812 - Cragar Soft 8 Black Wheels - Overview - SummitRacing.com
89 Blazer Lebanon 10-16-2012 05:10 AM
Originally Posted by newguy (Post 546180)
That's not a real fix!
89 Blazer Lebanon 10-17-2012 11:29 AM
Update:
Today I went and checked the front alignment, needed some camber tuning on one side. After alignment, rim was still touching the upper control arm. The guy told me that the problem is the ball joints which need to be on top of the control arm, he also told me that I can grind some off the arm if I want to keep the joints flipped.
So I came home, tried to grind a very little off the arm (as I don't like the idea of messing up with the touching point as it's the bent part that gives the arm it's rigidity), still the rim was touching the arm.
I flipped the joints on both sides L & R to top of control arms, and the rim is still rubbing against the arm.
What should I do? Could it be the caster (the guy told me that it was good)?
Jimmy's Jimmy 07-08-2013 05:03 PM
Rubbing on control arm
Hey, I have the same issue currently. I have stock rims with larger tires and the RC lift and control arms. I have found out the only way to solve it is to get a different offset wheel or get wheel spacers. It sucks.
newguy 07-08-2013 07:39 PM
When you crank the t bar you pull the top of your tire in making your rim closer to the arm. sooooo,,, offset rims, spacers, or a longer upper control arm. Longer arms come with lift kits. Thats about all you can do
newguy 07-08-2013 07:41 PM
And cranking your tbars is not a real lift
cleburne red 07-08-2013 09:27 PM
Dang! Well played, sir!
Thogert 07-09-2013 01:33 AM
Haha, laughed pretty hard at that one.
