Shocks Question
Dont know if it was asked
Are all 4 shocks the same ? found some Rancho RS9000XL for 80$ Each but dont specify if its for front or rear Are these good or should i go with Eldelbrock or even the Bilstein Thanks |
Not sure of your question if front & rear shocks are the same. But as a rule they are not on most vehicles. As for good shocks I have ran Rancho shocks the 9000s are pretty stiff the 5000 series is a great shock for the Ranger, Blazers, S-10, & Explorers. I think they still make a 5000 series. I ran a set on a 90 Ranger 4x4. They were great on dirt roads at high speeds & on the paved road as well. They worked great in real rough stuff also. But the very best shock I ever ran was the orange factory GM Blazer 4x4 shock. I'm not sure who made it for GM but I had a set on my 97 Blazer 4x4 & they are still going after I sold the Blazer with about 180,000 miles. I ran the crap out of that Blazer both on & off road. It went anyplace I wanted to go. The rode great, handled great, they took a beating.
Other than that depending on how you use your rig I have had no trouble with plain ole cheap Monroe gas shocks. In fact I have a set on my 98 Jeep GC 5.9 Limited. |
Orange GM shocks may have been Delphi* made in France. What I took off my Bravada, ... no idea whether they were OE or not but still relatively clean and still full of gas and no squirks when depressed. That said, Monroe Sensatracs ride significantly better.
Delco once actually made shocks. I worked in the shock plant for a week. Shock plant closed down in Dayton before the rest of ops were turned into Delphi. Front and rear are not the same. Even if the mounts were compatible, which they aren't, they would need different working specs. |
should i just wait and get the rough country kit with the 2.5" lift total with new gas shocks and control arm ?
better option ? http://www.ebay.ca/itm/ROUGH-COUNTRY...d=330626731983 |
I don't understand lift kits. I have been off roading since the 60s & I never saw any advantage to lift kits unless you were going for full competition & building strictly a race or climbing vehicle.
So I'm the wrong guy to advise on that. I have taken my stock height 4x4 in places trucks with lift kits couldn't go for fear of rolling them over because their center of gravity was higher. Just my two cents. |
that's why im only going for a 2.5" lift max, i just want to run 31" tires at most and need new shocks anyways :P
Originally Posted by r0k0
(Post 511989)
Originally Posted by 4x4blazerguy
(Post 511986)
So I'm the wrong guy to advise on that. I have taken my stock height 4x4 in places trucks with lift kits couldn't go for fear of rolling them over because their center of gravity was higher. Just my two cents. Edit: Sand isn't crap compared to mud. You'll appreciate bigger, more meaty tires in mud. |
yeah here is really more Rock / Mud trails... no sand stuff :P
Rancho 9000 shocks
I have a 1999 Chevy blazer ls 4/4 I need new shocks, I found some new rancho 9000 shocks that were for a blazer with a 4 in lift. Will these work on my blazer? I can get them cheap. The seller also said all 4 are the same, but the rear should have a two bolt on the top, would I need some other hardware?
| All times are GMT -5. The time now is 05:34 AM. |
