Sloppy Tie Rod/Whirring Sound/Hub Bearing
Hello all,
Got another question for you regarding my neverending Jimmy issues. When I got the truck I noticed what sounded like a bad front passenger hub, and also had the ABS light on the dash. So I replaced the hub and the ABS light went away but not the "Weoweoweoweoweoweow" noise that gains and slows with speed (on a side note, I have now changed front and rear diff fluid, t-case fluid - and inadvertently the transmission fluid since the inner seal is bad and it all dumped into the tcase.) Today I had the front passenger tire jacked up (drivers on the ground) and noticed I had a good 1 inch of side to side slop in the tire. I poked my head in and saw it is whatever the rod the tie bar connects to. Is this normal or no? I cannot seem to figure out where the hell that whirring noise is coming from. How am I supposed to check for a bad wheel bearing if the tires turn side to side that easily? Also - do these things 99 4WD SLE) not have any spring coils?? I was gonna try the "feel for vibrations" trick only to see a shock absorber and that's it... |
hold the tire top and bottom and check for play while someone looks at the axle. If the axle near the hub moves up and down your hub is bad. And you have inner and outer tie rods
Originally Posted by BeaterJimmy
(Post 700102)
Tires can make the whirring noise.
What kind of tires are you running? OEM style M&S? Big chunky ones? How does the thread look? Any play in the steering linkage should be addressed. Can cause some whirring too. |
Originally Posted by cleburne red
(Post 700149)
The 4wd trucks have torsion bars instead of coil springs
(Post 700223)
What kind of tires are you running? OEM style M&S? Big chunky ones? How does the thread look? Any play in the steering linkage should be addressed. Can cause some whirring too. I wish I could figure the dang thing out. Maybe I should just put it on jack stands and put in gear to see if maybe it's the rear wheel bearings instead although that seems extremely dangerous. There is really no chance though that a CV Axle could give that sort of noise? I've been listening to it around slight corners at speed and it doesnt seem to change. Under about 10mph I cant hear it at all so pulling into parking lots wont help determine. thanks for any advice given |
Preliminary actions I would do with such a problem. They are cheap and except for new tires need only your time.
Steering check: At 9 and 3 o'clock positions If this yields no conclusive answers I would in addition: - Take the wheels off again and check - Discs for discoloration (excessive) ruts and ridges damage, possibly outside and inside on the whole surface by turning the hub - Brake pads for wear (thickness over all, worn asymmetrically such as slanted) - Brake shields for not being loose, rusted away etc. - Brake hose and supports for looseness or any sign of contacting anything (rub marks) - ABS sensor cable for the same as the brake hoses All further operations would imply starting to tinker with the suspension and steering linkage. This could eliminate the bearings and wheels/tires and narrow down your problem - good luck. |
I have remarked you writing about ordering steering linkages. You write "torsion bar". Just to make sure there is no misunderstanding.
The 4x4 Blazers use "Torsion bars" instead of springs for the front suspension. These bars are mounted into the lower A-arm of the suspension and run along the truck inside of the frame, about under the front seats and insert into a forged H-Beam like crossmember under the transmission/engine. They are about 1 inch thick. I guess you reference to the steering linkage outer ball joints, adjuster sleeves and inner joints. We mostly see failing the outer linkage parts. The center adjuster arm and the pitman and idler arms are less prone to failure. You can change them independently, so going step by step on identified failed parts should be o.k. Make sure you get the wheels aligned after changing them. this will upset your steering. Can be done at home by measuring the length of the linkages very precisely or with the string method but is a PITA. |
