-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Solid axle Swap (https://blazerforum.com/forum/steering-suspension-drivetrain-36/solid-axle-swap-69842/)
madjay73 May 18, 2012 01:31 PM
sas jimmy
I have done a sfa on my 88 s15 jimmy. I used K5 blazer axles front and rear with the transfer case. It sits on 37 12.50 16.5 H1 military humvee tires. It is very high.
duxtoyz May 18, 2012 06:07 PM
im running dana44s out of a 79 ford bronco and a 78 scout with 5:39 gears and 39" tires with my 4.3L and it kicks a$$. astro van steering box and s10 blazer leaf springs all the way around. savage wheeler.
Anonymous907 Jul 19, 2012 11:21 PM
Your set up sounds sweet as hell. I'm looking to do a sfa swap up front and a larger rear axle. Did you have to do any custom fab or did it basically just bolt right in up front? I've never done an axle swap.
abig84 Jul 20, 2012 05:48 PM
wow good to see those axles holding up. im running 33s under my s10 with ten bolts which is pretty close to the 44s and i get paranoid sometimes
