| RhysThePiece |
02-17-2011 02:27 PM |
Squealing and airplane noise.
Hi, I have a problem with my 1996 4x4 4 door Blazer squealing. It's a high pitch squeal that almost rattles if you listen closely. It only happens when I have my blazer in drive or overdrive.
When I break, the squealing goes away completely (even when slowing down but not stopping) until I begin to accelerate again.
I also have an airplane noise that only happens when I decelerate. It stops around 10-15 miles per hour. Only happens in drive and over drive as well. As the speed slows down the noise gets lower in pitch. I didn't have the airplane noise until I took it in the shop and had my lower intake manifold gasket replaced. I checked transmission fluid and it seems to be very dirty and a little low. I'm going to get that filled and changed. Another thread suggested it may be a 4x4 issue on the airplane noise and suggested switching from 2 hi to 4 hi and low then back.
