steering shaft upgrade
read somewhere that the grand cherokee steering shafts work for 04 blazers. if this is true who has done it.. whats the reasoning behind it and what year grand cherokees should be used for donor...
It eliminates the "rag joint" at the steering box and replaces it with a "real" u-joint. It's easier, IMO, to just buy a replacement u-joint for the stock shaft from Flaming River or another aftermarket manufacturer.
"You would have to measure the shaft. If it is a DD shaft measure on the round ends. If you have a spline shaft, measure the diameter and split the shaft in half and count the splines then double the number to get the complete count."....... This is what i was told in order to order a U-Joint
Originally Posted by richards2004
(Post 727475)
I used the flaming river to upgrade my truck and am really happy.
I chose it because the reviews on here and S10 forum but you can get one much cheaper I don't paid as much as it is today but am happy. Here's an amazon link |
Originally Posted by Tom A
(Post 727483)
This the Borgeson joint I used. If you do a quick search, it should be pretty easy to find a part number for the Flaming River joint, as well. Or you can use any joint with a 3/4" 30-spline on one end and 1" double D on the other.
I just purchased the lower steering shaft that uses the factory upper shaft from Hooker (71223021HKR) 94-04 GM S10 steering shaft.
