-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Struts? Or coil springs? (https://blazerforum.com/forum/steering-suspension-drivetrain-36/struts-coil-springs-96207/)
SgtSquishySquash 01-28-2018 05:46 PM
Hey folks,
94 s15 jimmy 4wd.
bouncy ride.
replace struts?
or coil springs?
both???
thanks
christine_208 01-28-2018 06:14 PM
Originally Posted by SgtSquishySquash (Post 685854)
Hey folks,
94 s15 jimmy 4wd.
bouncy ride.
replace struts?
or coil springs?
both???
thanks
By struts I'm guessing you are talking about the shock absorbers. The springs can go bad (become less stiff with age and use) which would be indicated by the at-rest body height in one corner being lower than the rest. However this is rare as far as I know.
It is the shock absorbers that take some of the up-and-down motion and reduce the amplitude to smooth out the ride.
What you probably need is new shocks. Have you visually inspected them? Sometimes it is pretty obvious they are gone by oil leaking out of them.
SgtSquishySquash 01-28-2018 06:18 PM
I haven't looked at them yet. She's got 150k miles. And they are probably the original ones that came off the line with it.
SgtSquishySquash 01-28-2018 06:19 PM
I replace the shocks and see how it rides then. Also need to replace all the body mounts.
**I will replace the shocks**
christine_208 01-28-2018 06:25 PM
I had my one of my front shocks go out by 130k miles and 18 y.o. so it is pretty reasonable to expect them go out by 150k.
SgtSquishySquash 01-28-2018 06:29 PM
Ok thanks. For the quick response!
SgtSquishySquash 03-16-2018 09:44 PM
New struts/shocks all around. Rides like new now!
cleburne red 03-17-2018 02:45 PM
If yours is 4wd, it doesn't have coil springs. You've got torsion bars. And no struts, you've got shocks. But that was addressed above
Tom A 03-17-2018 03:43 PM
FWIW, my Blazer had 291,000 miles on it when I got it, and it still had the original shocks. I don't even know how the previous owner managed to drive it. It was seriously like piloting a boat on rough seas.:icon_pala:
