Stuck or dragging brake caliper? Collapsing brake hose?
2004 Blazer 4 door 4x4 LS
After any drive longer than a couple minutes the right front wheel is piping hot, and I can smell hot brake pad material (I know the smell from seating in new pads...). All the other wheels are cool to the touch. I verified this with my inferred thermometer; after parking for about 5 minutes, the other three wheels were between 120-130 degrees, the front right was 260-270... The truck does not pull to either side, while just driving it straight or when breaking, which I find odd... Thoughts? |
To me it sounds like the caliper is starting to stick. Have you tried to see how it moves by hand?
I personally have had more problems with calipers then brake lines, but I'm not ruling it out. |
Stuck caliper is what happened to me. Right rear. Couldn't really tell there was an issue by steering action; the sluggishness was the giveaway. Got a NAPA loaded caliper to replace it, probably should have checked the rotor but I didn't and 2,000 miles later I'm okay.
Not long after I posted that I figured I'd go ahead and tare into it.
https://cimg0.ibsrv.net/gimg/blazerf...c6a9ba8ce6.jpg You guys were right on the money. One of the pistons in the caliper was locked up solid... Notice how I was able to push one in but not the other... https://cimg6.ibsrv.net/gimg/blazerf...88dbdedc21.jpg Called the local parts store and I'm picking up both left and right calipers tomorrow as well as the left and right hoses. Might as well knock it all out at once. Must have caught it early enough because it doesn't look like the pads wore all crazy like and the rotor looks fine. Only visually obvious difference between left and right was some extra pad material build up in the slots of my drilled and slotted rotors lol https://cimg2.ibsrv.net/gimg/blazerf...03d9bfad6e.jpg Guess I can't be too mad, these things lasted 14 years on the truck. Bet the new/remans I'll be installing won't last that long... Wish I had the time to order in some braided hoses, but I really just want the truck back up and running at this point... Debating on weather I want to bother painting the new calipers red too just to speed up the process lol |
I imagine that you didn't do a pad replacement right before the trouble but it is also recommended to replace calipers at the same time you do new pads each time a brake job is done.
Regretfully the days of lasting parts is long gone, but I guess if the parts last the life of the vehicle they don't make money |
Where did you get your pads/rotors? Are they the rust resistant?
Originally Posted by odat
(Post 696293)
Originally Posted by DonL
(Post 696294)
As far as them being rust resistant, I don't remember anything in the listing advertising such, I live south of the rust belt so I can't really comment too much on how they'll hold up to winter roads and such. So far I've been very pleased with them though. |
I don't replace parts just because it's recommended either.
Back in the day the pistons were made out of steel and they could rust and pit causing seal leak and sometimes binding but usually took years to have any trouble out of them. Newer style went to ceramic or aluminum pistons - ceramic is prone to cracks while collapsing them and aluminum can crack but usually wear and grove causing seal leak. All in all IMO the steel were the best choice for wear and longevity |
(Post 696307)
Back in the day the pistons were made out of steel and they could rust and pit causing seal leak and sometimes binding but usually took years to have any trouble out of them. Newer style went to ceramic or aluminum pistons - ceramic is prone to cracks while collapsing them and aluminum can crack but usually wear and grove causing seal leak. All in all IMO the steel were the best choice for wear and longevity Had any of them had a couple rebuild kits on hand I would have just went that route... Get a little honer, clean them up, be just like new. But apparently that's a dying practice... |
I picked these up back at the beginning of the year off of Amazon, same idea, except they are apparently rust resistant. So far the only black that has come off, are where the pads touch. The rest is holding up. No rust build up anywhere, I'm really liking how they are holding up. https://cimg5.ibsrv.net/gimg/blazerf...5926c72471.jpg
| All times are GMT -5. The time now is 05:20 PM. |
