-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Suspension Lean (https://blazerforum.com/forum/steering-suspension-drivetrain-36/suspension-lean-103075/)
Stiner5811 03-01-2021 03:20 AM
Suspension Lean
I have a 4 door 98 4x4 and just installed the 3" rough country lift. I installed all new leafs and shocks. I replaced leafs cause I had a 2" difference between drivers rear and passenger rear. (Pass being lower). Everything is all torqued and squared up even and all new. Before the lift I had the same issue but all new suspension I have the same issue. I checked body mounts with all looking new. Frame doesn't have tweaks or kinks or any signs of bending or twisting. Just turned 90k miles and the under was undercoat and it's been well maintained but can't figure out why I have the lean. Anyone have any ideas?
Tom A 03-01-2021 08:33 AM
Double check the adjustment on your torsion bars. If the left front is high, it will make the right rear low.
Stiner5811 03-01-2021 11:17 AM
I check wheel spacing and all sit at 7 1/4 except for the pass rear is 5 1/4. I measured the torsion bolts and counted threads going in and even cranked in AL the way and backed out incase they started different
DonL 03-01-2021 11:54 AM
Did you push down on the bumper to create bounce and then check height? Only thing I can think, is if the shackles are angle different, does that not effect the pitch of the leaf spring?
Stiner5811 03-01-2021 01:12 PM
I jumped on it and even drove it a couple blocks after everything was tightened down to see if anything settled and nothing. Put an angle finder on shackles and the rear sway bar links and both sides are even. Even measured body mount thickness to see if they look good but was smashed and everything I can compare measurements on is square. I'm at a loss. I have an appointment at a 4x4 shop that does lifts to see if they can figure it out because I'm clueless.
DonL 03-01-2021 03:31 PM
Let us know what it is.
Only other thing I can think, is a bad shock absorber. But if it's new, then that's not the problem.
Did you do the leafs yourself? And where they new units?
Edit: as is new new, not new to you. Did they mess up and give you a stiffer one then the other?
Stiner5811 03-01-2021 08:03 PM
Leafs are new and installed by me from truckspring.com. the shocks are also new that came with rough country lift. I had the lean prior to the lift because I assumed a bad leaf pack or shock was my issue so figured go big when I replaced them is where the lift came into play.
