Suspension Tune-up?
Old Jan 20, 2009 | 04:43 PM
blazer man!'s Avatar
blazer man! is an unknown quantity at this point
Default Suspension Tune-up?
Hello, i need help on what parts i will need to replace when i tune-up my suspension. I know it is really bad but i have the stock shocks with 175,000 miles i bought it at 173,000 and i knew a lot needed to be done. I know it need ALL new bushings, new tie rods and tie rod ends, upper and lower ball joints, and idler arms. Is there anything else? It is really bad and i need to get it done.
Old Jan 20, 2009 | 05:23 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: Suspension Tune-up?
Synergy Offroad sells a nice full front end setup for these trucks (no sway bar bushings but all ball joints,tie rod ends, sleeves, pitman and idler arm included) I have not personally used it yet but plan to this spring have read many good things about this kit.
Old Jan 20, 2009 | 05:54 PM
Okay! Now it is a 4x4 so do they have those setups to?
Old Jan 20, 2009 | 06:08 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Fits 4x4 S10, Blazer, Sonoma, Jimmy.
Says it all in the description
Old Jan 20, 2009 | 06:13 PM
Okay thanks. Now do you suggest that anything else be done? I just had new rims and tires put on it but is there anything else?
Old Jan 20, 2009 | 06:36 PM
WolfPack's Avatar
Alignment after you get all that done.
Also check your rear sway bar bushings and leaf spring bushings.
Old Jan 20, 2009 | 06:47 PM
Outsydr's Avatar
well if your gonna go thru tearing it apart to put that whole kit on now would be a good time to check the control arm bushings out if they need replaced too you wont find a better time to do it.
Old Jan 20, 2009 | 06:48 PM
WolfPack's Avatar
Good point.
And check your front half shafts. Easy time to replace those guys too
Old Jan 21, 2009 | 05:26 PM
Okay i will i intern at a local Chevrolet dealership so I will take it down and do the alignment there and some of the work but I'm trying to save money by doin most of the work at home. Thanks for the advice.
Old Jan 21, 2009 | 08:08 PM
NVANZEE's Avatar
ORIGINAL: blazer man!
you should be able to get a good discount on all the parts you need through the dealer. not sure though if your an intern. i would think you could
