-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   sway bar question (https://blazerforum.com/forum/steering-suspension-drivetrain-36/sway-bar-question-38673/)
jaybird33081 Dec 31, 2009 02:49 AM
sway bar question
Hey,
Wondering what the part that the end of the sway bar connects to is called.
was under my 97 4dr 4x4 blazer just now and noticed the end of the sway bar was hanging little low and wasnt connected to the rubbery bolt kinda thing. Sorry for the terms i know next to nothing about suspensions. Is this a problem that I have to get fixed ASAP? What kind of problems can this cause. and how hard is it to fix?
neo71665 Dec 31, 2009 06:18 AM
end link
jaybird33081 Dec 31, 2009 07:23 AM
Originally Posted by neo71665 (Post 281506)
end link
Thank you, now i can google it and figure out how to fix it =)
Phil Dec 31, 2009 07:53 AM
Yep, endlink :) They're not that hard to replace so don't fret too much. I'm sure you can find a very good step by step online. If you've done one sway bar you've pretty much done 'em all. Then again I've only replaced sway bars/compenents on GM vehicles haha.
jaybird33081 Dec 31, 2009 01:40 PM
Well i figure i might as well do the bushing while i am at it also, they look pretty bad. do they get anykind of lube?
neo71665 Jan 1, 2010 11:25 AM
No lube and most any parts store has them.
jaybird33081 Jan 1, 2010 11:42 AM
so went to checker auto, got 2 end links, then there was 2 diff size bushings and I dont know what size sway bar i got. so i was just gonna get both sizes since they were only 11 bux each. then i figured i would use the one that fit and return the ones that dont. But of course they didnt have them in stock, nor did 3 other checker/Orielys. just cant catch a break sometime ha ha ah
jaybird33081 Jan 4, 2010 03:12 AM
well got the two end links in and 2 new bushings. Couldnt believe how rusted the old endlinks were. had to grind them off. Thanks for all the info guys. I appreciate it. =)
