Community
Search
Tcase front output shaft options?
Old 03-03-2019, 01:33 PM
cleburne red's Avatar
So, I've got the front out put and front driveshaft from a 98 Durango. It had a 231D HD case in it, with the wide chain. It already had a double cardon front driveshaft, I'm gonna see if a shop can get it to work in the Blazer.
Figured if it can stand up to a 5.7L hemi, my 4.3L shouldn't be able to hurt it!
  #22
Old 03-03-2019, 03:40 PM
Figured it might be beneficial to show a comparison of the two output shafts
​​​​The stock gm shaft is on the left, the Dodge fixed output shaft on the right.
Our stock shafts are slip yokes. A fixed output yoke, with the slip coupling in the driveshaft itself is a much better setup for lifted trucks.
I'll eventually be converting the rear output to fixed, as well.
  #23
Old 03-05-2019, 12:03 AM
odat's Avatar
odat is on a distinguished road
I know that a CV unit as in the front axles are a roller ball and cup/cage design and thu out the years I have seen a few more or less like them in drive shafts - but in the old school terms that I was taught your double Cardan joint is usually what I see and think of as a CV unit in a drive line.
  #24
Old 03-05-2019, 04:44 AM
Odat, you are correct. I've seen double cardan joints referred to as CV joints quite a bit online.
But our stock driveshafts have an actual CV joint, with ***** and a cage, so the waters get muddied quickly!
  #25
Old 03-10-2019, 02:50 PM
So, the case is all back together! I'm gonna let the sealant set up for a little bit, and fill it while it's still out, so I can leak check it.
​​​​​​Once I'm satisfied it's not leaking, I'll get it stabbed in, and actually get to see if the Durango driveshaft will work without modification!
  #26
Old 03-10-2019, 10:52 PM
Tcase isn't fully in yet, but it looks like the Durango front shaft will fit perfectly!
Looks like a front SYE and driveshaft upgrade for our trucks can be had for <$60 at a junk yard! (plus bearings/seals, rtv, pretzels and beer, etc)
  #27
Old 03-11-2019, 12:56 AM
That's good to know! I have a buddy that has a few Durangos sitting in his back yard.
  #28
Old 03-11-2019, 07:23 PM
OK so it is confirmed! A 1998 5.9L Dodge Durango driveshaft will fit perfectly into a second gen Blazer! After converting the front output shaft to one from the same Durango (as long as the tcase chain widths are the same)
​​​​​​I'm gonna replace the ujoints, and have it balanced, since I plan on doing the bravada axle shaft mod soon, and then it'll be spinning all the time
  #29
Old 03-11-2019, 07:42 PM
blazen_red_4x4 is on a distinguished road
This is awesome info! Great work sir!
Just to clarify, what year is your Blazer?
  #30
Old 03-11-2019, 07:50 PM
Mine is a 95. 233C (3 button switch). From my research, all blazers through 1997 had the wide (1.25") chain, so this swap should work. 98+ has the narrow (1") chain, and jeep XJ output shafts and yokes should work. Don't know about those driveshafts
Quick Reply: Tcase front output shaft options?
