Tie rod question
Been searching and have seen some comments- but not the answer I need. I order and received the 2.5" rough country lift kit and am waiting on a few wmore parts before I do my engine swap. I am going to go ahead and replace all of the steering components while I have the Blazer apart- and I am trying to decide on which tie rod ends. The factory installed ends are straight- but since I am lifting the suspension- would it be a better choice to go with the offset tie rod ends- or stick with straight?
thanks in advance |
https://blazerforum.com/forum/steeri...-blazer-55165/
Offset ones are for the zr2 model, which have a wider track width so I'm not sure if they are interchangeable like that EDIT: found this as well. Looks like the offset ones worked for this guy https://blazerforum.com/forum/steeri...rod-end-74223/ |
| All times are GMT -5. The time now is 07:41 PM. |
