-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   tie rods arent the same. Dont count em. (https://blazerforum.com/forum/steering-suspension-drivetrain-36/tie-rods-arent-same-dont-count-em-80402/)
chris015 07-12-2013 06:14 PM
So,ive noticed something on the last 2 sets on chevy cars ive done. You know the regular ol "count the threads" thing. Well,ive done it twice on 2 different gms. Aftermarket stuff is different. Just finished a astro van. HUGE difference. passenger way out, way out.
aka,dont trust the cheaper stuff as itll be off. Get it as perfect as u can then have it aligned. Alignment is MUST. his alignment was way off. the passenger tire was way off. aftermarket stuff is longer.
Thogert 07-12-2013 06:41 PM
When I did mine on the blazer I counted them and the thing was still almost impossible to drive in a straight line.
chris015 07-12-2013 09:26 PM
it made me sad. oem stuff was almost perfect on my old blazer when i did em.
cubawashere 07-12-2013 10:12 PM
when I do them I usually go with Moog, and I don't count threads, I usually use a paint marker, mark and let dry, then pull off the rod. I line up center of back to center of back usually at grease ports so I leave one fitting on and the other I take off so then fitting sits in back of other rod. Now I mark side by side the threaded end with the mark on OEM let dry and reinstall. Now that trick I've used on a variety of makes and models and usually comes pretty close every time. I do usually align after anyway, but then if needed I can wait if in a bind.
Twip 07-13-2013 11:07 PM
the counting thing is basically just to get it close so that you can drive it to the alignment shop. if you want to get it closer than that, i would suggest using a tape measure or something like that to measure it. its all about length.
chris015 07-14-2013 08:36 AM
correct.
The passenger side looked like you have the steering wheel turned half way. I just loosened the adjustment sleeve and pulled her in until it looked right,then went straight to the alignment shop. The alignment guy spent at least a hour on it. Im sure he was cussing me the whole time.EVERYTHING was off lol
newguy 07-14-2013 10:30 AM
Originally Posted by chris015 (Post 592454)
correct.
Well, you get your moneys worth that way
cubawashere 07-14-2013 11:55 AM
+1^ what newguy said....lol
