-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Torsion Bar Help (https://blazerforum.com/forum/steering-suspension-drivetrain-36/torsion-bar-help-24491/)
dew88 Oct 30, 2008 07:52 PM
Torsion Bar Help
I have read until I feel like my eyes are going to bleed. I am unsure and confused on this matter. I followed the torsion bars all the way to the back of the torsion bar where I found a key on the end. How do I adjust the torsion bars? Is there pictures somewhere or a good illustration I can read?
I normally don't post blind posts like this but I have never had a IFS before. All I have ever had a SFA. Thanks
PS If pics are needed I can take some. Thanks
WolfPack Oct 30, 2008 07:57 PM
RE: Torsion Bar Help
alllright fine :D
So...if you follow the tbar all the way back to the crossmember where the key is, you'll see the torsion bar adjuster bolt. It's a big bolt, I believe 3/4'. You tighten the bolt to raise the front end..1 full turn of the bolt = .2'-.25' of lift based on how worn your bars are.
The trick with measuring the height of the front end after you make a couple turns is to work the suspension out. It's best to drive down the street and back. Then measure.
I'll see if I can find you a pic of the adjuster bolts...but if you found the keys, you shoulda found the bolt ;)
mysons95 Oct 31, 2008 05:44 AM
Here is a picture of the rear end of the passenger-side torsion bar where you adjust it.
When you turn the bolt, it moves the key, which adjusts the bar, which raises or lowers your truck.
Clockwise = raise
Counterclockwise = lower
No more than 1.5" total raise unless you want to wear out parts faster.
http://tfdiamond.googlepages.com/pic...stmentarea.jpg
WolfPack Oct 31, 2008 07:35 AM
Nice pic! Still muddy I see;)
dew88 Oct 31, 2008 11:04 AM
Thanks so much guys I feel like a complete ass, I was right under and never seen it. LOL..
I like the SFA better, easier to lift. Is the torsion bars my only means of front end lift with the IFS?
WolfPack Oct 31, 2008 12:37 PM
Your torsion bars are your front suspension...so...just like lifting a SFA (coils/leaf), you gotta work with what youve got!
The only other options is a full kit from Superlift, BDS, or Trailmaster. The 2' kits give you better angled upper control arms to help the front end...and the 5/6' kits give you a whole assortment of brackets to drop the diff back down keep your CVs at safe angles. They still use the torsion bars as the suspension system.
I rather like the IFS though...
dew88 Oct 31, 2008 01:57 PM
In theory I like the IFS aswell however I see the Half shaft axles to be a pain in the arse. I already have a Dana 30 Jeep front axle with leafs and all. I have crossed the idea of a SAS but I don't weld.
ptg327 Nov 13, 2008 06:00 PM
i have a banging noise under my truck which everyone of my friends says its the torsion bar. i have a question and that would be is if i adjust the torsion bar bolts will the noise go away and in the process get a little bit of a lift outta the deal. the noise is coming from under the floor board where the passenger would put their feet. kinda close to the seat.
mysons95 Nov 13, 2008 06:14 PM
ORIGINAL: WolfPack
heh ;)
swartlkk Nov 13, 2008 06:48 PM
ORIGINAL: ptg327
Sounds like a busted mount on the passenger side of the torsion bar crossmember. Tightening down on the adjustment bolt will give you some lift, but it will not cure your problem.
