-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   transfer case crack (https://blazerforum.com/forum/steering-suspension-drivetrain-36/transfer-case-crack-57801/)
warthogdriver 04-11-2011 03:25 PM
transfer case crack
ok, i was checking out the underside today and spotted this.
http://i878.photobucket.com/albums/a...10411-1145.jpg
that is the location, roughly
here is the problem
ok, its not leaking from what i can tell....honestly i know nothing about the internals of what is behind that cover....i have no issues to report just this.
should i be concerned?
is there anything there that will leak?
thanks
swartlkk 04-11-2011 04:20 PM
That looks like it is the encoder motor. I'm not sure I'd worry about it much.
warthogdriver 04-11-2011 04:40 PM
ok, that works for me.
i might throw some jb on it just to forget about it.
thank you for the help.
swartlkk 04-11-2011 04:47 PM
If you are going to do something with it, pull the bolt and then pull that ear off. Clean up the edges and put the JB Weld only where it broke. Then put the bolt back in and tighten it down. That ear is part of the outside cover. The inside cover is still behind it, holding it on the transfer case.
warthogdriver 04-11-2011 05:25 PM
you read my mind, that was the plan.....actually i am glad you would do the same.
i tend to "patch" things sometimes.
